Chrysler Forums - Photo Galleries - Create an Account
Go Back   Chrysler Forum - Chrysler Enthusiast Forums > Chrysler Vehicles > Chrysler Voyager & Town & Country
Thread Tools Search this Thread
Old 05-03-2008, 01:15 PM
dphickster dphickster is offline
Default U110c message- no fuel level bus message
I've gone a long ways back on the thread and can't find anything on this. While driving, my RPMs sometimes drop, then come back. Error light came on and this is the code my reader came up with. My reader didn't have this error code in it's memory, had to look it up on line. Does anyone have any idea what I might need to look at to fix this?
This ad is not displayed to registered members.
Register your free account today and become a member on ChryslerForum!
Old 05-03-2008, 02:18 PM
Default RE: U110c message- no fuel level bus message
should mention: 2005 T&C with 3.3 and 51k miles
Old 05-04-2008, 12:33 PM
CHRYSLER TECH CHRYSLER TECH is online now
Send a message via AIM to CHRYSLER TECH Send a message via Yahoo to CHRYSLER TECH
Symptom:
U110C-NO FUEL LEVEL BUS MESSAGE
When Monitored and Set Condition:
When Monitored: Ignition on.
Set Condition: No fuel level BUS messages received by the PCM for 20 seconds.
POSSIBLE CAUSES
DTC RESET
COMMUNICATE WITH BCM
PCI BUS CIRCUIT OPEN FROM PCM TO BCM
BCM
TEST ACTION APPLICABILITY
1 NOTE: If a fuel level circuit or performance DTC is set along with P1681,
diagnose the circuit/performance DTC before continuing.
Turn the ignition on.
With the DRBIIIt, erase DTCs.
Start the engine on and off several times. Leave the engine running for at least 20
second each time.
With the DRBIIIt, read DTCs.
Does the DTC reset?
All
Yes ! Go To 2
No ! Refer to the INTERMITTENT CONDITION symptom in the
Driveability category.
Perform POWERTRAIN VERIFICATION TEST VER - 1 - NGC.
2 Ignition on, engine not running.
With the DRBIIIt, attempt to communicate with the BCM.
Can communication be established with the BCM?
All
Yes ! Go To 3
No ! Refer to the Communication Category and perform the appropriate
symptom related to no communication with BCM.
3 Turn the ignition on.
Using the DRBIIIt, read the Fuel Level parameter in the PCM.
Does the DRBIIIt display a fuel level value?
All
Yes ! Replace and program the Powertrain Control Module in accordance
with the Service Information.
No ! Go To 4
287
DRIVEABILITY - NGC
4 Turn the ignition off.
Disconnect the PCM harness connectors.
Disconnect the BCM harness connector.
CAUTION: DO NOT PROBE THE PCM HARNESS CONNECTORS. PROBING
THE PCM HARNESS CONNECTORS WILL DAMAGE THE PCM TERMINALS
RESULTING IN POOR TERMINAL TO PIN CONNECTION. INSTALL
MILLER SPECIAL TOOL #8815 TO PERFORM DIAGNOSIS.
Measure the resistance of the PCI Bus circuit from the BCM harness connector to the
appropriate terminal of special tool #8815.
Is the resistance below 5.0 ohms?
All
Yes ! Replace BCM in accordance with the Service Information.
No ! Repair the PCI Bus circuit between the PCM and the BCM for an
open.
__________________
14 Plus year Chrysler,Dodge,Jeep Tech I work at a dealer and I have a mobile repair service in ATLANTA. KKeller608@aol.com
Kevinsmobileservice.com
Master Electrical,Master Engine Performance,Master AC,
Master Body Mechanical,Master Brakes.2 year associates degree for Chrysler.
New business please take a look at it for me Serving Georgia natural gas and Texas for electricity.
http://kevinkellerenergy.igniteinc.biz
Old 05-04-2008, 05:50 PM
dude, a little more
english!!
Old 05-05-2008, 10:13 AM
if u want it done correctly U should have a dealer take a look at it from the diog it looks like U will need a DRB inorder to show what voltage is at the computers and such.
__________________
Old 05-05-2008, 09:00 PM
Thank you, but what is a DRB? The van is now parked at the airport while the wife is away on business. She reported that the light did not go out on the way to the airport. I've got 10 days grace to try to find other owners with similar problems before I will have it back to take to the dealer.
Tags
2005, bcm, bus, chrysler, code, concorde, cruiser, dodge, dtc, engine, fault, obd, p1681, pacifica, pt, trouble, u110c
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
Performance Parts
- Slotted Rotors
- Cold Air Intake Systems
- AEM Cold Air Intake
- K&N Air Filter
- Throttle Body Spacer
- Flowmaster Exhaust
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
