'04 300m sometimes won't start/alarm blinking
this is from bull dog alarms for a remote start something might be wrong with this . NOTE #1: this vehicle is equipped with CHRYSLER'S ANTI-THEFT TRANSPONDER System, that will
require a 791 bypass module and an extra key for operation or the XK09 Bypass
Module that does not require a key for operation to order go to the INTERFACE
BYPASS MODULE PAGE on this website.
What more does it do? Go off during thunderstorms, or when trucks or motorcycles pass. It's got an LED at the front and a momentary switch on the back and some wires coming out of it.
I took a quick look just now and found a white box under the steering column (but above some bracket so I couldn't see too well). All I could make out was "Pass Code System".
I'll have a better look tomorrow in the daylight.
#17
Okay, here is the box. I did some looking and found references to arming and disarming by pressing both arm and disarm buttons simultaneously, etc. I have a Chrysler remote with unlock, lock, trunk, and panic. Lock is "arm" and unlock is "disarm" but I don't know if that's going to get me anywhere.
Do these come with a spare key? Is that what's behind the little door looking thing on the opposite side? And if I wanted to remove this entirely (assuming it's the problem) is it easily done? Replacements of this are available on Ebay for $25 or so.
#19
So far the only thing that struck me as out of the ordinary was the light blinking twice, off, twice, etc. According to the docs I've found this means the car is in valet mode.
I have only two keys for this car - both came with it. The other day when I was having difficulty (four or five attempts/fails) I tried the other key and it started right up. That could mean something, or that could be coincidence. I'm carrying both keys with me and seeing if I can spot a pattern.
BTW, any idea what happens if and when the battery gets low in the remotes?
#20
low batt on remote has nothing to do with starting . by your pics there should be a box with another car key in it . so you should have 3 keys for your car . that is for when they bypass the oem system to make there system work. that key might be getting bad or the system or a loose wire depending on the install if they solder the wires .
