1995 Chrysler New Yorker 3.5 overheating at idle
Old 03-14-2014 | 09:02 AM
rdrodgers's Avatar
Some are double over head cams, some aren't. Sounds like you need to take the timing belt cover off so you can check the timing marks. Which V-6 do you have? Maybe I can find the right timing diagram for you.
Old 03-14-2014 | 09:11 AM
rdrodgers's Avatar
Try this link. May have to scroll down to the picture, then click on the picture.
http://repairguide.autozone.com/znet...52802683d9.gif
Old 03-16-2014 | 10:36 PM
Herbert Lofton's Avatar
Ok..thanks....When I have time I will....thanks...I'll let u know when I do
Old 03-17-2014 | 01:04 PM
95 chrysler's Avatar
I had the same problem . Very hard to fill. You need a special system to properly fill it. Dealer can do it. you need to use mopar fluid too
  #15
Old 03-18-2014 | 09:11 AM
rdrodgers's Avatar
A little late and a little wrong on responding to my problem. Mine had a cracked head that caused the coolant to be pushed out.
As for the "Mopar Fluid", mine has Shell brand coolant in it and is cooling fine now. As long as the coolant you use meets the standards set up by the manufacturer, you will be fine.
rdrodgers
08-22-2013 12:39 PM
Alguien
06-08-2011 04:52 AM
Jimbob
10-26-2010 03:13 PM
Alguien
07-02-2009 06:00 AM
Alguien
06-27-2009 05:48 AM
