1999 LHS no heat
Old 10-05-2008 | 06:41 PM
kentchris's Avatar
Default 1999 LHS no heat
I have a 1999 LHS with luke warm heat. I checked for codes, topped off coolant(not very low), blead air(only coolant came out). The first time this happened I put the temp down to low then back to high and I got heat. This is not the case any more. If I put the heat on high and auto the a/c icon comes on the display. I can here vent door move when switching from floor, dash, defrost.
Any help will be appreciated
Old 10-05-2008 | 08:34 PM
Iwant2playNOW's Avatar
Default RE: 1999 LHS no heat
I had the same problem on my 300M...it was the BLEND DOOR ACCUATOR...
Look back on previous posts to find the diagnostic procedure...you can run a test from the ATC module..it will display an error code.
Old 10-05-2008 | 11:20 PM
feel both heater lines into the fire wall both should be same temp if not clogged heater core.
Old 10-06-2008 | 07:38 PM
kentchris's Avatar
Iwant2playnow, I dont get any codes. Display flashes but if I hit any buttonit stops flashing.
Tech, I checked one before I posted. I will search for the other one and check it.
Thanks, Chris
Old 10-06-2008 | 11:59 PM
they are less then 1 inch from each other going into the fire wall.
allg32
12-23-2013 11:59 PM
reyesraiders1
11-11-2010 10:39 PM
simonda
01-03-2010 03:44 PM
davet
12-19-2007 05:18 PM
Screamineagle66
03-13-2007 03:42 AM
