2001 300M - Transmission
Old 08-18-2013 | 03:34 PM
jfyfe's Avatar
Default 2001 300M - Transmission
I have a relatively easy question for those with experience. Will the axle stubs turn (in drive or reverse) if the half axles are not installed?
I just replaced a failed transmission with one I got at the bone yard. The condition of the bone yard trans is of course unknown. Got everything put back together but wanted to see the stub axles spin prior to putting on the half shafts since they are such a pain in the a** to get off without damage. The stubs are not spinning and I'm not sure if this means the trans is no good or if I need to install the half axles to find out.
Thanks for any advice on this.
Old 08-18-2013 | 04:51 PM
whats an axel stub?
Old 08-18-2013 | 05:13 PM
jfyfe's Avatar
I'm probably using the wrong term. The splined stubs sticking out each side of the transaxle, where the half axle tripods slip over.
Old 08-19-2013 | 02:53 PM
on the trans itself no they dont move only when the CV axles are install its moves from the inside.
damjw3
03-14-2012 09:32 AM
amjaad1
06-11-2011 08:40 PM
lexusnrg
01-03-2011 03:23 PM
hackerill
06-09-2009 05:43 PM
Tomguy
01-01-2007 02:46 PM
