2001 LHS Auto Headlights
Old 06-28-2008 | 03:19 PM
JSchneid's Avatar
Default 2001 LHS Auto Headlights
My 2001 LHS has an intermittent problem where it will turn the lights on and off. This has happened while driving in daylight when they should not be coming on and while the car is parked. In the middle of the night, while the car is parked, the lights will go on and off at times. This is when the headlight selector is in the AUTO position. Any ideas or fixes?
Old 09-30-2008 | 10:25 PM
Wfoo's Avatar
Default RE: 2001 LHS Auto Headlights
I am having the same problem, did you find a fix?
Old 09-30-2008 | 11:15 PM
Iwant2playNOW's Avatar
most likely a bad switch...also could be the "solar" sensor, but i would bet on the switch
Old 10-01-2008 | 01:28 AM
Wfoo's Avatar
i hear a flickering sound in the dash as well when it happens, like a relay flipping. so i believe it is probly a bad switch.
Old 10-02-2008 | 02:47 PM
JSchneid's Avatar
Wfoo, No I have not found a fix. I suspect that the problem is from a defect in the Body Control Module. I am looking for someone who has had this problem and knows the cause.
Old 10-02-2008 | 03:20 PM
Wfoo's Avatar
have you tried replacing the switch? i will be changing mines today, and i will tell you if it fixes my problem.
Old 10-02-2008 | 03:35 PM
JSchneid's Avatar
No, I have not replaced anything as yet. I have another problem that I believe is also caused by a bad Body Control Module. See my posting on the other problem at
https://www.chryslerforum.com/m_1044..._/tm.htm#19490
Old 10-11-2008 | 10:14 AM
Wfoo's Avatar
my problem was fixed by replacing the switch, thanks alot for the input from all, i am extremely greatful.
Old 10-11-2008 | 10:31 AM
JSchneid's Avatar
Thanks for the info. I would not have thought it was the switch, just shows what I know.
solo4514
09-02-2011 03:10 AM
kemery1
06-29-2011 09:13 PM
billeisen85
05-06-2011 01:02 AM
Otis857
02-07-2011 09:44 PM
redpac
10-19-2007 07:45 PM
