2002-2004 300m
Old 06-15-2011 | 10:28 AM
boricuadon's Avatar
Default 2002-2004 300m
I have owned Chrysler and Dodge all my life..lost my last 2007 300 due to divorce. Looking to buy an older 2002-2004 300m..looks like better intrepid...any advice or comments would be appreciated. thanks in advance
Old 06-16-2011 | 06:23 PM
tinman's Avatar
I have owned, and still do, a 300M since they came out. I have liked this car a lot and on the whole it has been dependable. Sure, they have their problems like most cars, and they can be a pita to work on, but i recommend them wholeheartedly. Check out this link to the Chrysler 300M Enthusiasts Club.
tinman
Old 06-17-2011 | 12:04 PM
boricuadon's Avatar
thanks tinman,,I am convinced...I will be looking for the 2004 300m special..I noticed it comes with infinity speaker system. For the rear I already purchased (lol with no car yet but i had same set up in an 99 intrepid)..4 Kenwood 6993 6x9 5 way speakers. "I will remove the orig 2 and drill 2 more holes to install the 4 speakers in rear deck. Should I get a 4ch amp and how many watts? Each speaker handles:
Sensitivity 89 dB at 1 watt
Frequency Response 66 - 22k Hz
RMS Power Range (Watts) 2-120
Peak Power Handling (Watts) 500
Impedance (Ohms) 4
Top-mount Depth (Inches) 3 1/16
Bottom-mount Depth (Inches) 3 9/16
I will not be adding a sub...also what size can I get front speakers?
Old 06-18-2011 | 07:33 PM
tinman's Avatar
There is a ton of info over on that site. There is even an "Audio" section with some guys that flat out know what they are doing.
Old 06-21-2011 | 09:34 AM
boricuadon's Avatar
well i subscribed and was only able to get in once...page has tons of info but what good is it if logging on doesnt work..if clicking forgot password to get email doesnt work? if emailing admin doesnt work...ill stay here..
decided to get a some extra speakers by the way...i have so many questions though
for sure ill have the 4 rear deck speakers...replacing also the door speakers..now considering adding a subwoofer..or is it better to place the speakers on wood against the back of seat together with the amp?
i see a 4ch 2000w amp from pyle..is this enough? can i get a 6000w 4ch amp and bridge all speakers (4 rear, 2 door, and sub)?
Old 06-27-2011 | 08:47 AM
tinman's Avatar
I am not an audio guy, so I am worthless for answers to your questions. Sorry.
Old 08-06-2012 | 05:57 PM
delimabm's Avatar
I bought a used 2004 300m in 2006. Since then I have had to replace a cam shaft sensor , the a/c evaporator core, water pump, fuel sending unit and a $900 transmission repair. I did all the repairs which saved me thousands except for the transmission. The rims leak air with any tire I put on them. That was my first and last Chrysler.
chamber74
12-28-2008 04:37 PM
Clap07
12-12-2008 05:02 PM
sean284
11-24-2008 08:23 PM
bdevil
10-04-2007 03:06 AM
Netjunky
07-06-2007 11:25 PM
