93 concord
Old 05-09-2007 | 03:29 AM
jaysmilz's Avatar
Default 93 concord
93 concord v6
Will not idle. or will idle at round 500rpm until you hit the gas pedle and let off then will die
have to push accelerator to start
has mil codes 13 and 43
when codes are cleared it takes a few for code 13 (map sensor) to show anywhere from 10- 30 seconds
code 43 apeared onlyafter it sat idling at 500rmp for a while
plugs wires, coil, computer, and map sensor have been replaced, also the asd relay
thewires from the map sensor to the pcm have all been ohmed out and are good same with wires to ignition coil and asd relay, the conections are not corroded and seem in good order.
when i recieved this car it wouldnt start. had no spark half the time.. diag led to pcm ... replaced and now starts but with the problems above??? code 13 and wont idle...any ideas???
[/align]
Old 05-09-2007 | 09:34 AM
Default RE: 93 concord
sorry i dont have info on mil codes that go back that far if u get the p code might beable to do more
Old 05-09-2007 | 04:30 PM
jaysmilz's Avatar
code 13 - No difference recognized between the engine MAP reading and the
barometric (atmosphere) pressure reading from start-up.
code 43 - Peak primary circuit current not achieved with maximum dwell time.
[/align]
[blockquote]
[/align]c[/blockquote]
jc240zx
06-05-2006 01:56 PM
bryancollier
11-02-2005 06:47 PM
jc240zx
08-31-2005 07:04 PM
stberman
07-04-2005 01:04 AM
cloudrunner
06-23-2005 11:23 PM
