99 300M passenger power window and all door locks
OK on my passenger side front window it will roll down but not back up. I switched switches from another door and the same issue happens. I can make the window roll up and down if I directly power it so I know the motor is good. I put the switch on the back door and it works like its supposed too. all the door locks were working but now they have stopped as well. any ideas on how to track this down. the same relay that runs the power seats also runs the door locks and the seats all work correctly.
Help me out fellas
Help me out fellas
would there be a common ground or wire for all of these?
the lights on my door lock switches are working but the locks do not operate, also my radio and clock are now not working and my garage opener that was programmed in doesnt work. When I start the car the horn will beep once, could it be something to do with the anti theft? I unhooked the battery to see if it would reset but all isues are still there
I have power to the windows and door locks, have not found a bad ground from the initial problem of the window rolling down but not up fuses and relays are all good switches are good. tried resetting everything by disconnecting the battery but not sure if I left it unhooked long enough.
Could it be something to do with the anti theft, why does my horn honk once when I start the car?
Could it be a problem with the bcm, can I reset it?
And yes I would love for someone to tell me what the problem is, if I could figure it out myself I wouldn't be asking for help.
I don't usually just jump on here until I have done what I know to do to figure a problem out
Surely an experienced Chrysler Tech like yourself has seen this before and has some kind of idea besides "grab a wire diagram" , hell even a dumb ole shade tree like myself knows to start there.
An experienced Chrysler tech will tell u to do the same thing. Not all problems have the same cause each time unless its a known issues which this is not. U have power and ground from the switch on teh pass side? then the window will work so ooo what are u missing power or ground to the pass side switch not allowing the motor to work? The wire diagram will give that insite. Common scene why would an anti theft system stop one window from working? and the BCM does not control the windows this is ere that wire diagram i asked for you o get comes in handy no guess work. Why your horn honks could be an aftermarket alarm system who knows.
Didn't really think the anti theft would be the window problem, was leaning more towards that being the reason the door locks suddenly quit working and the horn honking when started. Guess I'll be tearing it apart over Thanksgiving holiday!
MrSaratoga
11-24-2013 06:10 PM
97LXIgirl
01-29-2011 08:47 PM
MichaelB
01-17-2011 12:38 PM
kelgilbert
07-29-2008 05:52 AM
