99 300M shuts off while running
Old 02-11-2007 | 02:43 PM
BigHurt's Avatar
Default 99 300M shuts off while running
OK, I have everybody, including the dealer, stumped on this one: I have a 99 M with 100k miles on it. About 3 weeks ago the local temperature got about 15 degrees F and it has remained that way or colder since. At the same time. I began to develop a problem where my car would just shut off on its own while I was driving. At first it would happen after doing about 15 minutes of city driving. Now it does it almost immediately. Car used to restart immediately, now it requires me to drive 2-footed to get it to start without stalling.
I initially had my spark plugs replaced and my throttle body serviced. Then, I had my crankcase and cam position sensors replaced. Then, I had the dealer find and fix a vacuum line leak. Then, I found and fixed a loose connection on the positive clamp going to my battery.
There have been no check engine lights or codes. The car seems to run more reliabley after driving it for a while, though my tach seems to be acting a little erratic (i.e., I take my foot off the accelerator while going up hill and rpm remain at 1500, jump up to 1750, then decrease to match speed).
The problem always occurs after the car has sat overnight in freezing temps.
I am getting ready to ditch this car. Any last minute suggestions?
Old 02-11-2007 | 02:45 PM
BigHurt's Avatar
Default RE: 99 300M shuts off while running
I suspect something with the fuel delivery system, such as fuel pump or fuel injectors....
Old 03-13-2007 | 11:27 PM
slammedmark8's Avatar
Try getting a induction flush done on it.. Kinda sounds like it could be carbonded up. Just a thought
Old 04-06-2007 | 02:19 PM
justliving's Avatar
I had the same thing happen, on my 96 Sebring.. After sitting 8 hrs at a dealer, The mechanic came out and told me he worked on Chryslers for 30 years and this was the first time he seen this..( Found it , by accident ).. An O-ring blew out of the egr valve... Might want try replacing it (cheap part ) on the 300 M.
JaxJim
07-24-2014 10:46 AM
BigHurt
10-16-2012 05:55 PM
Gpeter1983
02-28-2012 11:58 PM
seveniron36
12
12-29-2011 12:23 PM
wgcbamc
12-17-2011 02:22 PM
