'99 Concorde Blower Fan only works on high
Old 01-02-2009 | 10:43 PM
marshlk's Avatar
Default '99 Concorde Blower Fan only works on high
My '99 Concorde does not have the auto temp control feature. The blower fan recently will only works on high. Is there a fuse or resistor located where a backyard grease monkey canfind and replace by himself?
On my '94 Concorde I had the auto temp control feature, and the problem with that (fan on high heat defrost all the time) cost over $300 to fix several years ago.
Old 01-03-2009 | 04:34 PM
billbon8's Avatar
Default RE: '99 Concorde Blower Fan only works on high
Hello,
I just had this happen on my 01 Concorde. There is a resistor block on the passenger side near the fan. Just follow the wires and disconnect. Two plugs go to this part. The part is a little tough to get out (it's tight around thetwo 8 mm hold down screws). For my car, the OEM part is 04885845AA. I got it from Ebay for $27.00 (shipping included). Make sure that you get the one 'Not For ATC Systems'. It took me about 1/2 hour for the part swap. Apparently, this is a common failure part on these cars.
Good luck...
Bill
rye2
08-31-2012 10:31 AM
esu
06-14-2012 01:44 PM
courtney frias
04-14-2012 12:15 AM
dm6174
11-11-2009 06:39 PM
jesuslike
07-26-2006 05:46 PM
