99 LHS question...
Old 04-18-2010 | 08:47 PM
dvaughn669's Avatar
Default 99 LHS question...
ok first of all my 3.5 has broken a valve spring. So during the tear down i get to taking off the crank pulley and no amount of prying will pull it off. Is there a trick to removing this that I dont know? Ive done several timing belts and have never had this type of problem before.
Old 05-04-2010 | 08:47 PM
tginley's Avatar
Crankshaft dampener puller kit. 3 claws that hook on the center flat sections and has a set of 3 rods that fit inside the 18 MM crankshaft bolt. No amount of pulling is going to get it off. If you pry it or attempt to you will damage the crankshaft. Any auto parts chains will lend you the kit for free.
Davidsed
14
03-25-2013 09:51 PM
clhs
03-15-2011 09:06 PM
2000LHS
10-03-2010 03:16 PM
boosted5speed
07-23-2009 11:23 PM
val197826184
02-15-2008 09:53 PM
