99 LHS starting troubles
Old 01-08-2012 | 10:30 AM
RT469's Avatar
Question 99 LHS starting troubles
My 1999 LHS starts and runs fine, BUT occasionally when I shut it off and try to restart it after 10 to 45 minutes it just turns over. It acts like it wants to start but wont. If it does start it acts like it is flooded and runs rough untill I play with the throttle and get it to rev up and then it is fine. While trying ot start it during this time the accelerator pedal is hard, like it won't move at all, then when it tries to start the pedal will move free.
Any ideas??
Old 01-08-2012 | 10:34 AM
RT469's Avatar
Forgot to mention that if it sets for any longer than the 45mins after shutting it off it will start no problems.
Old 01-08-2012 | 07:00 PM
check for spark and fuel see which one u are missing
Old 01-20-2012 | 05:04 PM
RT469's Avatar
I have checked and it has both!
Old 01-20-2012 | 06:25 PM
so when it wont start up for u U still have spark and fuel???
Old 02-03-2012 | 08:37 AM
RT469's Avatar
Thats right Tech. It sounds like if someone was to kick the car as I'm tring to start it it would start. While cranking it tryig to start it sound as if it will start but when you let off the key it has not started. Do you think it may be a weak fuel pump? When my Charger did a similar thing I bumped the timing and it started fine after.
Old 02-03-2012 | 11:34 AM
check fuel pressure see what u have
wintereighty7
11-22-2012 12:51 AM
ollerich29
10-20-2012 09:56 PM
gato_solo
06-23-2011 07:31 PM
Jonieshilo
01-27-2008 02:15 PM
JimboXL
02-22-2007 01:44 AM
