ATC a/c blowing heat only
Old 08-04-2007 | 08:56 PM
Jon87transam's Avatar
Default ATC a/c blowing heat only
hi, my name is jon, i'm a newb here and a newb with mopar. i just bought a 94 LHS (110,000mi) and my a/c w/ATC will not blow cold. it is charged, and compressor kicks on, i don't have any control of the temp. it blows out constant heat. when auto is pressed, it flashes a few times on the display, then goes out. temp readout and temp adjustment is working on the display. anybody got any ideas? i'm thinking blend door actuator. any help is greatly appreciated.
Old 08-05-2007 | 04:38 PM
kissmyaspen's Avatar
Default RE: ATC a/c blowing heat only
Well, the only help I can give is that the reason the display blinks when you push auto is you have to set the temp to 72 for some reason... Than it'll work with auto... Sorry it's not much info...
Old 08-05-2007 | 04:41 PM
you told me more than i knew, so it's a help. i thought on my dad's 96 intrepid it would go into auto at any temp, but i don't remember anymore. thanks, anybody else?
Old 08-05-2007 | 10:24 PM
Gonna put the ATC in diag mode
Set temp to 75 enter diag mode by pressing floor,mix and defrost at the same time. When the panel starts to blink release all 3. The test will make stuff blink. Once the test is finished a number or set of number will be displayed wright them down and get back to me. Only one code at a time will be displayed press the vent button to scroll down and see there is more then one code.
Old 08-06-2007 | 01:01 PM
as soon as i know i will get back to you. i won't get to work on the car until this weekend as it will be sitting at another guys house while i work on it. i appreciate the help, thanks!
arihan
08-17-2024 08:33 AM
ChryslerNightmare
05-07-2011 02:14 AM
kbrod7
06-05-2010 02:36 PM
marty1966
08-11-2009 12:23 PM
NTOLERANCE
10-21-2008 10:10 PM
Quick Reply: ATC a/c blowing heat only
