A/C Dripping
A/C Dripping
Whenever i run the A/C in my 95 Concorde it starts to drip after awhile, this drip ends up as a puddle on my passenger floor. I have een told that my condenser drainage hole is plugged, but i have no idea where that is or how to even check it. Any Ideas?? thank for the help.
RE: A/C Dripping
I do not know specifcally where it is on your Concorde, but it is a small stub (maybe an inch) coming thru the firewall, down low on the passenger side. Once you find it, use something to "rod" it out (i.e. pipe cleaner, piece of wire, etc). The drain allows the condensation that comes off the evap to drain out of the vehicle. If the drain is clogged, eventually it builds up to a point that flows out on the floor.
rgang10
11-24-2007 10:26 PM
