Can outer boot on transaxle be replaced? - '99 300M
Old 06-11-2009 | 11:00 AM
SVT3267's Avatar
Default Can outer boot on transaxle be replaced? - '99 300M
The outer boot on trans-axle (front, left) is torn, some of the internal grease has leaked. Is it possible to replace only the rubber boot? If so, how laborious would it be?
Old 06-14-2009 | 09:33 AM
dadh68's Avatar
Default boot replacement
you could get a split boot and put that on. It will work for a little while, I've never really had very much luck with them. I normally remove the half shaft (axle) and replace the boot..
Old 06-15-2009 | 03:47 PM
SVT3267's Avatar
How much labor to remove the axle and replace the boot?
Old 06-15-2009 | 10:40 PM
You have to disconnect the ball joints and remove the steering knuckle. It's a big job.
shovel55
02-23-2013 01:59 PM
bgeise
11-30-2012 08:05 PM
kubick
06-12-2011 09:30 AM
mkweaver
06-11-2011 09:14 PM
theoldscout
05-06-2010 02:07 PM
