Changing bcm
Changing bcm
Ok, My first is: If i change the BCM on my" M" for a new ,i know that i had to use a DRB III to enable the VTSS in order to start the car , ofcourse if the BCM´s are the same module year and same part number , but if i get one used , could i have problems with the VIN too?
But is possible use one used ? in the service Manual only mention to enable the VTSS , do not mention VIN for the BCM , but I read somehere that the BCM learn it self the VIN .
BCM-changed
Hi, again , news : I got one used BCM from a 2001 300M -USA , there are some diferences between this 2001 module and mine previous year 2000 module , but today i changed the modules , and changed some wires to , in the switchs to match with mine , some time ago i changed the OTIS to EVIC with TPMS , but not all the options worked ,or worked bad and changed the MHSMM to , got tilt mirrors on reverse but lost easy exit sit, well today after this wires changes , and plug the battery again , was the moment , , first ,tested ligths,wipers,AC,memory , and guess what ? it´s all working , and all option with grafics on the EVIC to , get the easy sit again ,and started the motor and did not stalled ,only the remote radio switchs do not work yet, and i have to get new fobs to the RKE , but my car have only 22000 Km on it , and with this "new used BCM" displays 223 000Km , can this be changed with the DRB III tool ? and for this 2001 RKE i have do you know what is the right part number of the key fobs?
no the miles cant be changed that is why I dont use used BCM because of that and now that U have changed from what U had as far as part numbers your old fobs wont work I bet. A dealer might be able to tell u based off the part number of the new bcm what fobs might work.
News, wired the remote radio switchs to the clockspring , and now the radio can be controled by them , and found a tool to reprogram the rigth KMs on the BCM to , only the ambient temp. sensor is not working so well , is displaying wrong temp , the wires were changed from the BCM to the PCM from 2000 to 2001 , when i have time, will change them to , maybe work, what do you think about?
