Changing bcm
Old 07-16-2009 | 09:37 AM
300MV6's Avatar
Default Tool-to change miles
You can see it on Ebay or Google - M-CORRECTOR :mileage correction tool for driver use - they sed that works fine.
Old 07-16-2009 | 12:45 PM
its 450 bucks for that tool to use one time U could have paid the same amount got the right bcm and did not haft to wire up or change anything and all things would be working just as they should
Old 07-17-2009 | 05:24 PM
300MV6's Avatar
Yes , if my previous BCM had some problem on it, but this change i made was not because that , but to get all the new 2001 model options working,if i ordered one new from Chrysler , they will sent one like mine , same part number and year model and to order one new to 2001 model , with so many telling , don´t do that ! will not work , the models are not interchangeable , well could i run that risk ? yes was a shot in the dark , but worked ...
I know , is not a easy do it your self job , and i could advice to not try to do this without knowleage about how to do it - many hours with the head on the books is not for all .
Old 07-17-2009 | 05:46 PM
300MV6's Avatar
Default Mopar remote start system working on 300M
Ok , new!
Mopar have a remote start kit to new models , not for Chrysler 300M , another part that will not work on a 300M ,and not with EVS Security system, well why could not this model work on a M?
I bougth one for a Dodge Ram , yes, and the service manual to, many hours around this question , reading , and decide to change some wires , and switchs , now works fine on my "M" , start/stop the motor, etc.
Question -Later, updated to the 2-way Kit , but lost the hood swith function , no one could tell me what is the part number for the 16-way hood switch , is that possible?
Any help ?
Ah! works fine with the EVS II - when start , disable the alarm , stop ,enable again , and do not open the doors.
  #15
Old 07-17-2009 | 06:04 PM
300MV6's Avatar
Default 300M European model-Auto ligths on
- 300M for the European market , are diferent , are rated almost like the Special , Odo with 240Km , Hid ligths , 254HP , all with Premiun options and performance handling Group , but without the option Auto headligths, why? don´t know!
Ok , asked for this , is possible to have this option ? No offcourse not!
Again around the books , if the car have ligth sensor, on the dash , interior mirror with sensor two , is the premium , let´s run open the switch and check , , get lucky again , all i need inside , just broken a stoper inside the switch , and got the "A" position to the left , and is working well , and the ligths on with wipers to , and for the end put a rain sensor to have auto wipers .
Divelucaya
01-25-2011 12:39 PM
mr_strick
01-16-2008 04:24 PM
mongoose53207
03-08-2007 12:55 AM
quattj
02-02-2007 11:30 AM
Carlclemans
01-11-2007 12:01 PM
