electrical controls problem please need help
Old 02-19-2012 | 08:20 PM
airforce1's Avatar
Unhappy electrical controls problem please need help
On my 1999 300M the head lights quit working, the tail lights quit working, the
power locks quit working, the internal heater blower motor runs on high full
time, the switch does not matter what position it is in. Gas gauge quit working, and wind sheild wipers and
all digital display on the trip computer & heater console has no information
displayed.
Old 02-19-2012 | 10:13 PM
TNtech's Avatar
What about ignition switch functions/positions. Does the car start and run? Do you have automatic temp control?
Old 02-20-2012 | 04:55 AM
airforce1's Avatar
yes car run fine and starts the ac is auto checked all the fuses everything is good but if you go the the relay and jumper pin 30 and 87 on that circuit will work like the head lights will come on for testing and i can test others the same way with jumpers
Old 02-20-2012 | 10:00 AM
TNtech's Avatar
It appears that you have lost a bunch of BCM functions. It's under the driver's dash attached to the fuse box. You can try unplugging/plugging it and see if it comes back. The 2 grey connectors.
Old 02-20-2012 | 07:44 PM
airforce1's Avatar
ok these controls make all this stuff work will try thanks
Old 02-21-2012 | 05:33 AM
airforce1's Avatar
Found nothing so far ,do you think it's in the ignition switch or in that fuse section because thats a lot of main control not firing power I may have to get one from junk yard
xtremez28
12-11-2014 12:33 PM
airforce1
02-20-2012 04:49 AM
jfryling
10-08-2011 09:59 AM
dandyd
08-15-2008 12:37 PM
drains
03-28-2007 10:07 PM
