LHS Radiator Drain
Old 12-19-2007 | 06:00 AM
ffhuie's Avatar
Default LHS Radiator Drain
Hello, I read and applied everything my haynes manual stated to do for a radiator change prior to a flush for my 97 LHS, however no fluids came out. I removed the cover for the radiator resovoir, turned the radiator drain **** (only turned 1/4 counter clockwise turn), and removed the entire radiator hose bleeder valve/plug instead of just opening it. I do know that I didn't follow the step to remove the radiator drain plugs on both sides of the engine block 1-because I couldn't find them, 2-because I don't know what they look like, 3-because I was told that because I was doing a flush (Prestone radiator flush) I could get away with just draining what is immediate to the radiator. Does anyone know where the drain plugs are on the engine? Should there be fluids draining from what I did or did I miss a step? thanks! Brian.
Old 12-19-2007 | 04:41 PM
moe's Avatar
moe
Default RE: LHS Radiator Drain
hey ffhuie,heres where and what your drain plug looks like.you might have to remove it all the way out to get fluid to flow.make sure your replace the o ring before yout reinstall.moe
Old 12-21-2007 | 04:34 AM
ffhuie's Avatar
Thanks for the image. However, I'm not sure about how to remove the drain ****. It only turns 1/4 turn counter clockwise and I tried pulling the drain **** out, but it didn't even move. Any sugguestions?
swright227
12-10-2018 06:08 PM
chrysler2001
12-31-2014 12:48 AM
7Enigma
13
11-16-2014 02:24 AM
VFRbeliever
Cirrus & Breeze
12-08-2007 02:30 PM
slikrik99
08-07-2007 01:24 PM
