Oil on my intake valve???
Old 06-11-2011 | 08:06 PM
mkweaver's Avatar
Default Oil on my intake valve???
Vehicle: 1996 Chrysler LHS (3.5 Liter V6)
Symptoms: runs rough at idle - no check engine light.
I took this to a mechanic who told me the problem was a leaking intake manifold gasket. Since a gasket set costs $6 and the shop wanted 2.5 hours labor to replace it, I decided to do it myself.
I now have the intake manifold off and looking in the intake runner I can see what looks like oil puddled around the rear intake valve (driver side rear cylinder).
I rolled up some paper towel and reach in to sample the fluid. After letting it dry for a few minutes I put a match to it. It didn't flame up as quickly as I would have expected gasoline.
Assuming this is oil and not gasoline (from the removal of the fuel rail) I see only two sources - a leaking head gasket, or shot valve stem seals.
Does it seem I am headed down the right track here? If so, is there a way to isolate the source of the oil short of removing the head?
Any pointers are appreciated.
Mike
Old 06-11-2011 | 09:08 PM
mkweaver's Avatar
False alarm - it turns out I was seeing gas from the removal of the fuel rail. When I went back to look it had dried up.
I didn't want to have to remove the head.
Is there anything else I should do while I'm in this far?
Old 06-19-2011 | 08:10 AM
anwaypasible's Avatar
clean the injectors?
have the injectors tested for flow?
what are the chances one injector spits out less gas on purpose to keep the engine balanced?
i would clean the injectors at least.. probably not much else that can be done except test the injectors for flow compared to stock (or a new one).
syxx20603
01-25-2010 02:54 PM
billbon8
07-29-2009 10:54 PM
sumncguy
07-24-2007 10:35 PM
xtreme1_419
05-16-2005 11:17 PM
