Options if timing is one tooth off after cranking
My passenger side cam timing mark is one tooth towards passenger side after setting the timing on the 300M. Crank and driver side cam marks still there. What are my options? (I have not loosened either cam bolt but moved both cam marks by hand) Thanks!
Why is AC pulley grinding on its tensioner housing?!
Got the 2000 300m started after timing belt/water pump, thermostat, drivebelts replacement job, started it up and got a rattling noise and noticed the ac pulley looked loose (it wasn't). Stopped the car and the pulley is pulling up against the housing and grinding metal on metal? any ideas? Thank you!
tucsonflash
02-07-2013 04:21 PM
jly2258
07-29-2011 12:07 AM
