Overheating and leaking antifreeze
Last night I ran into a problem with a 2000 lhs. It started overheating and is leaking antifreeze/water on the front passengers side of the car. it seems to be coming from under the radiator. any ideas? (2000 lhs 3.5L)
The car needed oil. But I'm in the works of needing a head gasket replacement, because there's steam like smoke coming from the tail pipe even after the car has warmed up. No disrespect, but I hate chrysler/dodge. They don't use quality parts for longevity.
BTW I have 340,000 on my 91 Caravan - how's that for LONGEVITY? but I DO occasionally change the oil, but not as much now as before.
And if you want to check the engine - do a compression test... tells U a lot and any home mechanic can do it with a $10-20 tester that will last U a lifetime. I bought one when I was 16, still have it, still use it.
i didn't suspect the oil because i didnt hear any ticking and i saw a leak from the radiator and there wasnt any coolant in the resevoir. but wow a head gasket replacement? i'll have to take it to my college and let them do the job for free. oh one more unrelated qiestion, when 1 turn signal bulb blow does this make the rest not work?
