Overheating, Puking, Coolant Loss
The other day my 300m overheated very quickly and puked coolant and steam every where. So far I have checked the fans, hoses, and individual cylinder compression. All of those are good, and there is no noticable loss of coolant under the car. After tons of bleading of the system the heat started to work again. Tomorrow I will take the thermostat and water pump out. I will probably replace both either way.
Is there anything I am missing?
RE: Overheating, Puking, Coolant Loss
ORIGINAL: master tech
Did the fans stay on all the time when you were driving? And did they ever turn off?
Right now it is in the air. I went for removing the thermostat, but once again the cramped quarters ran me off. Is it worth the extra room to remove the alternator and oil filter? I need an oil change anyway I guess. What sizesocket is used to adjust the alternator belt tensioner?
Thanks for the help!
i would look into the radiator being blocked before taking out the stat.the location sucks,if its only while your driving.in all the years of working on these 300's ive only repplaced 2 stats and one was because i was rebulding the engine.moe
ORIGINAL: moe
I have removed the top and bottom mounting bolt for the alternator. Are there any other mounting bolts? Do you have to remove the bolt holding the electrical wires to the back of the same hole as the top alternator mounting bolt? How do you get the top alternator mounting bolt out of the hole? Its brake time, but I am set on getting this alternator out today.
I finally broke down and removed the upper radiator support. It was much easier to do than I thought, and it gave me tons of room to work. Tomorrow I will buy more coolant and test the system out. I also plan to check the torque on the tie rod I installed last week.
ORIGINAL: moe
FX-IT-FLX
02-19-2017 01:24 PM
Clayton
06-07-2010 09:19 PM
tandc99
08-06-2007 06:59 PM
