Where is the oil pressure sensor located on 2000 LHS
Old 01-22-2011 | 10:32 AM
djnagle's Avatar
Default Where is the oil pressure sensor located on 2000 LHS
Hi All, my oil light started flickering when I would stop and a light, then go out when I took off. Then it started flicking and staying on up to high way speeds where it would go off above 2000rpm. The engine is not over heating and I am not hearing any lifter clack so I ASSUME it is the sensor. I picked one up today but it is 4 degrees out and I really dont want to spend more time in the driveway than necassary. I can't afford the manual so I thought I'd ask here.
Does my assement of the problem sound right?
Thanks much.
Old 01-22-2011 | 01:12 PM
engine size?
Old 01-22-2011 | 04:24 PM
djnagle's Avatar
Sorry bout that. It is the 3.5 SOHC
Old 01-22-2011 | 05:04 PM
pass side on the side of the block
Old 01-22-2011 | 05:29 PM
djnagle's Avatar
Thanks C-Tech. Damn it is too cold to be doing this.
Old 01-23-2011 | 10:42 AM
djnagle's Avatar
OK, I jacked the car up and the Oil Pressure switch was on the drivers side right next to the oil filter. But there is a problem. The Oil Pressure switch does not mount INTO the block, it mounts to a housing that has a line attached to the side of it. The housing seems to mount to the block but it is very loose and no oil is comeing out of it. I stopped there because I didn't want to snap the line going into the housing.
The engine does say 3.5, but also High Output and has "24 valve" on the valve cover.
Any suggestion on how I should proceed?
Old 01-25-2011 | 06:07 AM
djnagle's Avatar
Tuesday morning bump. Has anyone run into this?
alaskanJK
02-06-2021 10:00 AM
Vikingtu
08-16-2014 11:24 PM
chicago11
01-03-2011 07:28 PM
vettman
08-15-2006 12:20 PM
12-05-2004 03:56 PM
