Are you are sure that this particular model is compatible with fitting it into your different vehicle?
Also I believe that many models have the choice of being VIN coded.
If the VIN has already been loaded into the radio then no code is required.
But if no VIN has been loaded, then the correct radio code will have to be entered every time the battery is disconnected.
It looks as though you may have to take it into a Radio Decoding Workshop to be fixed
#542
This means that the code may not be available for free from anywhere on the Internet.... but you could try asking your local Chrysler dealer
Otherwise , if you are in a rush , try emailing
restoredclassic@aol.com
Mention this Forum
#549
These T00AM radios are made by Mitsubishi and the codes cannot be calculated but have to be looked up on the Chrysler Dealer database
Otherwise, if you cannot wait, then try emailing
Mention this Forum
Mention this Forum
