2007 Dodge Ram Features & Options
2007 Dodge RAM features/options:
Models:
ST
SLT
TR X4 Off-Road
Sport
Power Wagon
Laramie
Regular Cab
Quad Cab
Mega Cab
Engines:
3.7L Magnum V6 (215 @ 5,200 235 @ 4,000)
4.7L Magnum V8 (235 @ 4,400 300 @ 3,500)
4.7L FFV Magnum V8 (235 @ 4,400 300 @ 3,500)
5.7L HEMI V8 (345 @ 5,400 375 @ 4,200)
6.7L I-6 Cummins Turbo Diesel (325 @ 2,900 610 @ 1,600)
Transmissions:
4-speed auto
5-speed auto
6-speed auto (68RE with ERS, will replace 4-speed auto later in model year)
6-speed manual
Transfer Cases:
- Manual (NA on Mega Cab or 1500 Regular and Quad Cab; standard on 2500/3500 4x4)
- Electric shift (standard on 1500 Regular and Quad Cab 4x4)
- Electric shift (standard on all Mega Cab and 2500/3500 Regular and Quad Cab Sport and Laramie models)
- On Demand (optional on 1500 4x4 only excluding Mega Cab)
New features/options:
- 1500 Laramie models come standard with 5.7L HEMI V8 engine
- Active turn signals activate the signal with a tap. Requires less effort during lane changes (Standard on all models)
- Electronic Stability Program includes Hill Assist (Standard on 1500 Laramie, ABS is included on other 1500 Regular and Quad Cab).
- SXT Value Group includes steel chrome-clad wheels, power locks, power windows, power mirrors, cloth 40/20/40 bench seat, carpet with floor mats, and speed control
- Power accessory delay (Standard on all models)
- Snow Chief Plow Package (Optional for 2500 gas engine models). Includes unique box side reflective decal, 160-amp alternator, transfer case skid plate, 750-amp battery, antispin rear axle, cab clearance lamps, LT245/70R17E tires, SLT/Sport receives vinyl flooring standard.
- TIP Start prevents double starts and preserves battery and starter life
- Remote Start System (Optional on models with V8 engine and automatic transmission combinations)
- YES Essentials® easy-clean, stain- and odor-resistant seat fabric is included on specific cloth seats
- Diesel exhaust brake for 6.7L Cummins Turbo Diesel will be a factory-installed option that can assist in deceleration of the truck.
- Electronic Vehicle Information Center (EVIC) on instrument panel packages with Cummins® Tubo Diesel
Exterior colors:
Bright Silver Metallic
Bright White
Brilliant Black Crystal Pearl
Electric Blue Pearl
Flame Red
Inferno Red Crystal Pearl
Light Khaki Metallic
Mineral Gray Metallic
Patriot Blue Pearl
Interior:
Khaki
Slate Gray
Radios:
- AM/FM stereo radio with CD player and 4 speakers (REF )
- AM/FM stereo radio with MP3 plug-in integrated 6-disc CD changer and 7 ∞Infinity™ speakers (included with Sound ’n Secure Value Package) (RAQ)
- AM/FM stereo radio with MP3 plug-in integrated 6-disc CD changer, integrated DVD-based GPS Navigation System with 5.8" display screen and 7 Infinity speakers (REC )
- AM/FM stereo radio with MP3 plug-in, cassette, in-dash 6-disc CD changer and 7 Infinity speakers (RAK )
Standard equipment on all models:
Active Turn Signals
Air Bags (1500 Regular Cab and Quad Cab feature advanced front multistage )air bags)
Next Generation multistage front.â€* Passenger-side on/off switch on Regular Cab (all Mega Cab, and 2500/3500 Ram models)
Air Conditioning
Alternator
Armrest, Center
Battery
Brake/Park Interlock (With automatic transmission)
Brakes (Power-assisted four-wheel disc)
Bumpers - Front and rear
Cargo Box - Double-wall construction with high-strength steel floor, stake pockets, cargo tie-down cleats, two-tier loading and bulkhead provision
Child Seat Anchor System (LATCH ) — Lower child seat anchors and upper tether anchors help ease the installation of compatible aftermarket child seats
Console, Floor, includes two cup holders (with manual transmission, not available with automatic transmission)
Center business console, with storage area (SLT, TRX4 Off-Road and Laramie)
Cup Holders, Front, Lower instrument panel-mounted (two) (with automatic transmission)
Floor console-mounted (two) (with manual transmission)
Cup holders, Rear, Two floor-mounted (Quad Cab) (not available on ST models)
Enhanced Accident Response System
Fuel Tank Capacity
— 26-gallon (1500 Regular and Quad Cab short box)
— 34-gallon on short box (Mega Cab and 2500/3500 Regular and Quad Cab models)
— 35-gallon on long box models
Glass - Tinted
Instrument Cluster — Speedometer, trip odometer, tachometer; indicator lamps for 4x4 operation, maintenance required, antilock brake, seat belt reminder,
air bag, low oil, and check engine, gauges for oil pressure, engine temperature, voltmeter, fuel level, engine hours meter
Insulation - Dash liner & Floor tunnel
Lighting, Exterior - Cargo lamp with integrated center high-mounted stoplamp
Lighting, Interior - Dome lamp
Mirrors, Exterior
— Dual manual, 6"x9" black (ST)
— Dual power, heated, folding (SLT, TRX4 Off-Road, Sport, Power Wagon, Laramie)
Power Accessory Delay
Power Accessory Outlet - 12-volt, located in instrument panel
Radio - AM/FM stereo with CD player and four speakers
Seat Belt Cluster Lamp — Stays on after engine start until driver buckles up
Seat Belts, Front - Height-adjustable Unibelt three-point restraint system (including center position on Regular Cab) with traveling buckles and Constant Force Retractors
Seat Belts, Rear - Height-adjustable (Mega Cab only) Unibelt three-point restraint system with traveling buckles and Constant Force Retractors
Spare Tire - Full-size with wheel
Steering
— Power-assisted rack-and-pinion (1500 Regular and Quad Cab; all 2500/3500 4x2 models)
— Power-assisted recirculating ball (all Mega Cab 2500/3500 4x4 models)
Steering Column - Tilt
Steering Wheel - Four-spoke
Storage
— Cab-back storage with molded floor tray (Regular Cab)
— Rear underseat compartment (Quad Cab)
— Behind rear seat enclosed (Mega Cab)
Sun Visors - Driver and front-passenger, sliding, cloth-covered (driver-side map pocket on SLT, Sport, TRX Off-Road, and Laramie)
Suspension
— Front, independent coil spring (all 4x2 models)
— Front, independent coil-over-spring (1500 Regular and Quad Cab 4x4)
— Front, solid live axle with coil springs and four trailing links (Mega Cab 2500/3500 4x4 models)
— Rear, longitudinal leaf springs
— Heavy-duty front and rear shock absorbers and front stabilizer bar Tailgate — Removable with quick-release latches
Transfer Case
— Electric shift-on-the-fly 1500 Regular and Quad Cab® 4x4 and Mega Cab® 4x4
— Manual shift-on-the-fly (2500/3500 Regular and Quad Cab 4x4)
Wheels and Tires - 17" (20" standard on 1500 Sport)
Winch - Tire carrier
Window - Rear-door full drop-down glass (Quad Cab)
Wiper System - Windshield, two-speed with speed-sensitive intermittent mode
Option packages (partial)
Big Horn Value Package — Chrome billet grille, fog lamps, body-color bodyside moldings (if sport exterior colors), black bodyside moldings (if other colors), SIRIUS Satellite Radio, manual sliding rear window, Big Horn badge, 20" aluminum wheels and P275/60R20 all-season tires (1500 Quad Cab Short Box only, NA in Northeast, Mid-Atlantic or Southeast Business Centers or Texas).
Big Horn Value Package 2 — Black bodyside moldings, manual sliding rear window, 17" forged polished aluminum wheels (included on 3500 only with SRW,) fog lamps, Trailer Tow Group, tow hooks (included with diesel engine), SIRIUS Satellite Radio, Big Horn badge and leather-wrapped steering wheel (2500/3500 Quad Cab only, NA in Northeast, Mid-Atlantic or Southeast Business Centers or Texas).
Lone Star Value Package — Chrome billet grille, fog lamps, body-color bodyside moldings (if sport exterior colors), black bodyside moldings (if other colors), SIRIUS Satellite Radio, manual sliding rear window, Lone Star badge, 20" aluminum wheels and P275/60R20 all-season tires (1500 Quad Cab Short Box only. Only available in Texas).
Lone Star Value Package 2 — Black bodyside moldings, manual sliding rear window, 17" chrome-clad steel wheels (included on 3500 only with SRW), fog lamps, Trailer Tow Group, SIRIUS Satellite Radio, tow hooks (included with diesel engine), Lone Star badge and leather-wrapped steering wheel (2500/3500 Quad Cab only. Only available in Texas).
Quad Cab Value Package — Cloth 40/20/40 split-bench front seat, carpet floor covering (includes carpeted floor mats), body-color upper front fascia, black bodyside molding, speed control and 17" chrome-clad steel wheels (1500 only).
Single Rear Wheel Group — Includes 11.5" axle, 9,900-lb GVWR, 6"x9" black outside mirrors (ST) or 6"x9" power heated black mirrors (SLT and Laramie), LT265/70R17E tires and 17"x7.5" (ST) or 17"x8.0" (SLT, TRX4 Off-Road, Sport and Laramie) wheels (requires diesel engine; standard on all 3500 Short Box models, optional on 3500 Quad Cab Long Box only).
Sound ’n Secure Value Package — AM/FM stereo radio with MP3 plug-in, integrated 6-disc CD changer, ∞Infinity™ speakers and Security Alarm (Quad Cab® only. Must have Big Horn, Lone Star or Thunder Road Value Package. Available nationwide.
Thunder Road Value Package — Chrome billet grille, fog lamps, body-color bodyside moldings (if Sport exterior colors), black bodyside moldings (if other colors), manual sliding rear window, SIRIUS Satellite Radio, Thunder Road badge, 20" aluminum wheels and P275/60R20 all-season tires (1500 Quad Cab Short Box only. Only available in Northeast, Mid-Atlantic and Southeast Business Centers).
Thunder Road Value Package 2 — Black bodyside moldings, manual sliding rear window, 17" forged polished aluminum wheels (included on 3500 only with SRW), fog lamps, Trailer Tow Group, SIRIUS Satellite Radio, tow hooks (included with diesel engine), Thunder Road badge and leatherwrapped steering wheel (2500/3500 Quad Cab only. Only available in Northeast, Mid-Atlantic and Southeast Business Centers).
TRX Group — 17"x8.0" aluminum wheels, chrome grille surround, gray upper fascia, P265/70R17 OWL on-/off-road tires, and unique decal (only on 1500 4x2; NA on Quad Cab Long Box).
TRX Group 2 — Chrome grille surround, gray upper fascia, P265/70R17E OWL on-/off-road tires, and unique decal (only on 2500/3500 Short Box 4x2).
TRX4 Group — 17"x8.0" aluminum wheels, unique painted shocks, gray upper fascia, P265/70R17 OWL on-/off-road tires, and unique decal (only on 1500 4x4 models; NA on Quad Cab Long Box).
TRX4 Group 2 — Unique red-painted shocks, P265/70R17E OWL on-/offroad tires, and unique decal (only on 2500/3500 Short Box 4x4).
Work Special Group — Includes Dark Gray grille surround, Dark Gray upper front fascia and rear bumper, and 17"x7.0" wheels painted argent (1500 Regular and Quad Cab only).
Models:
ST
SLT
TR X4 Off-Road
Sport
Power Wagon
Laramie
Regular Cab
Quad Cab
Mega Cab
Engines:
Transmissions:
4-speed auto
5-speed auto
6-speed manual
Transfer Cases:
Exterior colors:
Bright White
Electric Blue Pearl
Flame Red
Patriot Blue Pearl
Interior:
Khaki
Slate Gray
Radios:
Active Turn Signals
Air Conditioning
Alternator
Armrest, Center
Battery
Fuel Tank Capacity
Glass - Tinted
Mirrors, Exterior
Steering
Storage
Suspension
Transfer Case
rr44230
04-03-2010 04:42 AM
aimee
01-07-2009 11:03 PM
