04 2.4 dohc wont start
Old 03-21-2012 | 11:40 AM
check for spark and fuel at the engine
Old 03-21-2012 | 01:42 PM
Jay04's Avatar
No spark at all from the brand new wires
Old 03-21-2012 | 03:23 PM
Jay04's Avatar
Maybe the coil pack?..Ill wait for a respone because I don't want to keep throwing new parts at it I learned my lesson with her Taurus and then found out it was warped heads
Old 03-21-2012 | 04:19 PM
no spark then check for 12volts at the coil and then the other 3 wires will have a ground pulse when starting the car see which one u are missing
  #15
Old 03-22-2012 | 02:13 PM
Jay04's Avatar
#1 not firing on the coil pack 2,3 & 4 have a dim spark..someone told me it might be the camshaft or crankshaft sensor but if it was wouldn't it pull a code?
  #16
Old 03-22-2012 | 04:57 PM
Possible coil pack Unplug the coil pack connector check for 12v with key on it will come on for a few seconds then turn out. then check for ground pulse on the other wires at the connector
  #17
Old 03-25-2012 | 08:04 PM
Jay04's Avatar
Th coil pack test out good even tried a new one put its still not starting..does this model have a fuel cut off switch and if yes where is located..I really need this car back on the road its er only means to get the kids back and forth to school
  #18
Old 03-25-2012 | 10:56 PM
no there is not a fuel cut off switch U said no spark so why would something like a fuel cut off switch stop spark? I would
suggest taking it to a professional and get your car back on the road.
  #19
Old 03-26-2012 | 12:21 AM
Jay04's Avatar
my mechanic friend keep saying crankshaft sensor but wouldn't that pull a code?..I hate going to a shop out here in texas they seem to over charge..ill try the sensor in the a.m
  #20
Old 03-27-2012 | 09:18 PM
Jay04's Avatar
Ok update..I've kept the new coil pack on just update,checked for fuel at the injectors abd almost blinded myself with gas,changed the camshaft sensor because it was bad looking,the timing belt is still on and I'm going to change the crankshaft sensor but can't find it(if anyone know where its located please tell me)and its still not starting..any ideas anyone?
