'07 Brake Lights Not Working
Old 11-07-2010 | 09:20 AM
dmosterd's Avatar
Default '07 Brake Lights Not Working
'07 Sebring Touring. Brake lights are not working. Fuse is OK. Brake light switch has power on only one pin. Any help is appreciated.
Old 11-07-2010 | 12:30 PM
TNtech's Avatar
Are you using a test light or a meter? Does the center brake light work?
Old 11-07-2010 | 01:16 PM
dmosterd's Avatar
Using a meter. Center light does not come on.
Recently had the alternator changed. Could it be the TPIM?
Old 11-08-2010 | 01:45 PM
TNtech's Avatar
OK, I would put a brake lamp switch in it. I say this because the TIPM operates the brake lamps on the lower L/R by way of a high side driver(no fuse) after recieving the BS signal over the BUS. The third brake light is a hardwired circuit from the TIPM fuse #3 10A. You have no brake lights at all so the most likely issue is with the switch. There is a far chance it could be the TIPM but having 2 dead circuits at the same time is rare. Just to be sure check the red wire going into the BS, there should be juice there. Press brake pedal and the Green/ White tracer should light up. If not the BS is bad. The wires will be in pins 1 and 2 of the BS connector.
Old 07-15-2017 | 03:44 PM
Jennlad's Avatar
Default No brake lights
I have a 2007 chrysler sebring my Centre brake light works but my right and left don't we thought the brake switch so we changed it but no difference. Any ideas on what it could be?
4everrunning
06-04-2019 12:30 PM
murphypat16
10-04-2013 09:39 AM
kendude33
10-09-2010 10:09 PM
mikeg
09-30-2010 09:52 AM
calpacifica
08-26-2007 05:40 PM
