1996 Chrysler Sebring JX... No Spark to Spark Plugs
I did put a new distributor... 2 times matter of fact... The first time was a distributor from a 1996 sebring JX... It didn't work... Sooo, I went to autozone and bought the $230 distributor in... Still dont work...
I'ma try using a hairdryer and blowing it on the PCM... See if it gets warm and try to crank it again... See if it works!!!
I'ma keep you updated...
Well finally after 6 months... My car has has been fixed I put it in a shop... It needed a new engine wire harness the wires leading to the distributor were worn off... Thanks for helping out tho... Thank god... I really needed a car!!!
#15
98 Sebring convertible V6 getting fuel but no spark
I have a 98 Sebring convertible V6 it has no spark the low fuel light came on and it died thought it ran out of gas put 5 gallons of gas in it now I have gas coming to the injectors but no fire . I took of the intake and removed distributor and replaced the coil put the distributor back in still no spark and you can smell gas in the intake holes do I'm sure the crank sensor is ok . It's driving me crazy no codes from the computer ran like new before the low fuel light came on i also checked the auto shutdown relay it's good too driving me crazy anyone got any suggestions?
#17
Did you check the condition of the wire connector and harness to the distributor? (broken/corroded)
Also that the rotor is fully seated to the dist. shaft, I've heard that some have had problems with that.
My 98 2.5 Avenger(same platform) isn't home right now to go check a few things for your concerns,as mine has never given me troubles, other than leaky VC gaskets and an alternator! My wife's daily drive, IF I can pull some time with it, I check a few things on it and get back with you!
#18
I'm planning on going threw voltage checks tomorrow I'm going to down load some wiring diagrams later . It's got to be something simple I am over looking I bought it to resale ran fantastic then like I said I went and got a pop at the station pulled out and low fuel light came on do I turned around to get gas and it acted like it ran out of gas I have it brought home and it has no spark it's getting gas because I smell it real strong . I just hate pouring more money in it already changed the coil so next I check wires
#19
You may have replaced the coil in the dist(but there are other pieces in there that can go bad), and did you check the cap and rotor for wear/failure while it was apart? Rotors can go bad and not distribute the spark. You may want to pop off the small timing belt cover by the P/steering pump and check that the timing belt is in fact intact...that old you never know.
#20
I've checked the cap the rotor button I've checked the actual coil for spark . The cams are both turning so I don't think it's the belt . If the timing belt was out of time you would still get fire just at the wrong time. I'm thinking it's a bad wire connection. I'll go nuts but I'll figure it out i put all the parts back in didtrdistri correct also I think I'm just wore out and missing something I'll check all the voltages on it tomorrow and see if I can find it out thanks .
LemonSebring98
04-17-2011 09:42 PM
1996, 96, chrysler, clicking, convertable, convertible, crankshaft, engine, jx, plugs, position, sebring, sensor, spark, started
