1997 Sebring Jxi convertible - can't put fuel in it!!!
Hello everyone. I have a 97 sebring convertible with the 3.5 6 cylinder engine. I bought the car about six months ago from a friend. He told me that he had a new fuel pump installed and that they had to drop the fuel tank to do it. Since then, I cannot fuel the car up correctly. It backs up the fuel neck after only a few cents of fuel. I have zero idea what and why to check....
Are there check valves in the fuel neck that maybe the guys installed upside down? I have checked under the car and none of the hoses seem to be crimped or such.
I hate that it takes me 20 minutes to put in $20 worth of gas. (the people behind me in line don't seem to be happy with me either...lol).
Any advice?
Any advice?
The check valve is built into the tank, not the fuel filler hose. I do not believe it is sold separate from the tank. To replace it, you must replace the tank. Check with the parts guy at a dealer to be sure about that. Anyway, to get to it, you must remove the fuel tank.
Could it be that your buddies kinked the fuel filler hose when re-installing the tank? If that's the problem, you can probably fix that without buying a new tank, though it may be necessary to drop the tank out of the car again.
Drunkenwood
07-27-2009 09:02 PM
sumncguy
07-13-2007 12:33 PM
Buzter
05-18-2007 09:55 PM
