1999 sebring convertible will not start after replacing the starter
Old 02-04-2012 | 06:30 PM
p8ntballnxj's Avatar
Default 1999 sebring convertible will not start after replacing the starter
This morning, my sebring decided to not start at all. I get full power on lights, etc but when i turn the key, nothing happens.
So i tested the battery, thats not the issue. Then i replaced the starter, that still didnt fix it.
Im lost right now...
Old 02-04-2012 | 08:26 PM
So what is it doing? Crank but no start? No crank?
If no crank, then get out your volt-ohm meter and trace the juice from the battery to the key to the starter relay to the starter.
Check for bad grounds.
Don't start replacing things unless you have determined that they are bad.
Old 02-05-2012 | 08:23 PM
TNtech's Avatar
Look for blown fuses under the hood. Specifically a yellow 20 amp
LisaG
06-20-2020 06:44 PM
lost-in-space
Cirrus & Breeze
12-05-2014 11:36 PM
snickingaround
07-02-2014 06:42 PM
RickZler
06-18-2011 09:19 PM
HiVoltg30
02-26-2011 10:00 PM
