2.5l Valve cover gasket & boots replacement
Old 10-02-2012 | 01:29 PM
Basic's Avatar
Default 2.5l Valve cover gasket & boots replacement
99 2.5l(Mitsubishi) Chrysler Sebring
minor leak that in oiling my alternator causing brush failure
Looking for any tips before I dive in. I have the new set and copper sealant(if needed?)
What should I expect?
what are the torque #'s?
What else should be done @ the same time
Also asking for the sending unit location
Thankyou.
Old 10-02-2012 | 10:32 PM
Label all the wires and hoses so you have no problem putting them back where they belong.
Plan on replacing the spark plug tubes at the same time. You'll need the sealer for the bottom ends of the spark plug tubes.
Valve cover bolts should be tightened to 30 in-lbs (not foot-lbs) in three increments. Tighten them in a criss-cross pattern starting in the middle and working outwards.
Don't know which sending unit you're referring to, but try going to chryslerparts.net and looking up your engine there. They have parts diagrams that might show where it is.
Old 10-03-2012 | 12:23 AM
Basic's Avatar
Thankyou Sir!
Old 10-03-2012 | 03:32 PM
Basic's Avatar
Well sir, I cant seem to find any micro film of anything on that site. My part yes
placement of no. Im lost
Im speaking of the oil pressure sending unit.
Old 10-03-2012 | 03:35 PM
Basic's Avatar
is this correct???
(C&P'd)
"2.5L engines, the oil pressure sending unit switch is located on the engine block, below the front exhaust manifold on the radiator side."
Old 10-03-2012 | 05:43 PM
Basic's Avatar
TTTop
Old 10-03-2012 | 08:20 PM
Basic's Avatar
fOUND DIAGRAMS
OE Parts Mega Stores
Old 10-03-2012 | 08:25 PM
Originally Posted by Basic
is this correct???
(C&P'd)
Don't know. Crawl under and have a look. Post up your findings.
two gun
12-01-2014 09:45 PM
David Rovka
01-01-2014 10:36 PM
loggerbomb
Cirrus & Breeze
01-01-2013 02:02 PM
tntandc
03-24-2008 05:46 PM
sumncguy
07-24-2007 10:35 PM
