2001 Sbring Conv. Starter replacement
Thanks in advance for any help you can provide.
I need to replace the starter which appears to be located behind the front engine mount. Looks like you need to remove the engine mount from the block, is that correct or is there a easier way?
Thanks,
Gary
Thanks,
Gary
You need to remove the front downstream oxygen sensor, then remove the engine mount through-bolt. Then remove the engine mount bracket from the engine block.
Remove the battery cable from the starter and remove the lower starter bolt and the starter should come out.
aqualungtj1
09-11-2009 09:48 AM
Drlawgr
12-27-2008 10:41 PM
