2001 sebring convertable coolent fans
Hello, I have a 2001 sebring convertable with the 2.7 engine, The radiator cooling fans do not come on, but if I turn the AC on they cycle the way they should. Any one have any one have any thoughts on this problem? Thanks, Steve
My temp gauge went out, I bought a new sencer the one by the bleed screw, however the old one does not unscrew, it just turns, do you think this could be the problem with the temp gauge? I need the gauge to see if the car is running hot. Thanks, Steve
Search the forum here for a great deal of discussion on replacement of this part. It's called the coolant outlet manifold, water outlet and some other names like bleeder block and (mistakenly) the thermostat housing.
Now that you have spun the sensor in the housing you can bet that it will start leaking. Most of them fail eventually, so don't be surprised that yours has too.
With the correct tool, it's not a difficult repair. Use "gear wrench" for your search term in the forum and you'll find out how to do it.
Hello I bought the whole stand with sender from amazon.com for 43.00 with free shipping than joined a credit card co. they gave me a 30.00 gift card to that new bleeder stand so the stand cost me 18.00 to my door, what a deal. hopeing it fixes my temp gauge, Thanks Steve
That will work if it's shallow enough. Apparently you didn't search the forum as suggested or you'd have found a link to a picture of a gear wrench. Anyway, with the proper tool, you'll find this an easy project. No need to pull the upper intake manifold.
