2001 Sebring Convertible
I just had the drivers side window motor go down. Where can I find details (maybe with pictures) on how to replace it? I have had the panel off and I can see the motor and regulator but not exactly sure how to remove the motor.
It's covered in the shop manual, but not real well, and hardly at all in the Haynes manual. If you've got the door apart, you're halfway there and can probably figure it out with patience and perseverance. Generally, you need to prop the glass in the up (closed position), then unbolt the regulator and motor combination from the glass and the door. Then you extract the motor and regulator out through the large opening in the door inner panel. Be sure to mark the positions of the fasteners on the door before you undo them to preserve the location of the glass adjustment. Hopefully when you put it back together it will all be in the same place and more-or-less properly adjusted.
01goldsebring
11-14-2009 11:05 PM
johnacastro
06-09-2008 05:30 PM
