2001 Sebring LE instrument panel problem
Old 05-25-2008 | 05:25 PM
anabel99's Avatar
Default 2001 Sebring LE instrument panel problem
Hi, I´ve a Sebring LE 2001, this week when I start on my car I´ve problem whit somes indicators in instruments panel.
When I turn on the instruments that measuring fuel, temperature and speed goes to the middle scale.
I check that the car have the tank fuel fully, and the temperature is cold and no move the car.
I check the car in a official dealer service and tell my that the car work´s OK!!!.
I hope that anybody have some similar problems.
Any suggestions are welcome
Thanks in regard.
Old 05-26-2008 | 10:13 PM
irdaneel's Avatar
Default RE: 2001 Sebring LE instrument panel problem
My 99 Sebring guages are very sluggish, but within about 3 minutes have settled in. (Especially after refueling) If they are continuously reading in the same position then there is a problem. It is likely in the cluster of guages, or perhaps the entire thing. It could also be in the connections at the back of the cluster.
Check ALL of you fuses both inside and under the hood. Wiggle some wires and connectors around under the dash and under the hood (Gently!) to see if you get any response. If not, you'll probably need a new instrument cluster.
Brian0514
12-07-2010 11:34 AM
71grande
05-23-2010 09:55 PM
Josho
11-25-2008 02:24 AM
TheCoutures
09-17-2008 10:04 AM
sistegraf
12-21-2007 06:23 PM
