2001 Sebring won't start
Old 02-04-2012 | 01:28 AM
Diffendbecker's Avatar
need a little more back ground then what u have told on here. All of the above posts were due to wrong engine being put in is yours the same issue?
No...
I drove on my 02 Sebring Convertible, 2.7 and the noise shows up... like something touching the FAN (metal noise) I tried to switch transmission from "Drive" to neutral or to parking - everything fine. Dynamic of the car is same as earlier. I came to practice and in 3 hours after practice I've tried to start it, but it doesn't starts. I tried to start it many times, but no result. The car was towed to my apartment. I bought the OBDII scanner and it showed P0700, P0725. I bought new Crankshaft sensor for 15 dollars in AutoZone, took of previous (metal part was out of sensor inside the transmission). Using the screwdriver I very carefully took of the metal part from old sensor and insert new. Then I tried to start the car, but no result (only 5 seconds, because my battery died). I tried to read the codes, but scanner said "No DTC data". When I trying to start the engine... during the starter working... my RPM goes over than 1000.
Next day morning I tried to unplug connector from CAM Sensor and car starts, but with plugged in to CAM sensor connector... P0340 and doesn't starts. (RPM are jumps over 1000) I don't know, what to do. I tried to change CAM Sensor and I didn't do anything else.
dlukanec
08-22-2019 04:25 PM
2005Cruiser
08-20-2018 09:46 PM
jbda
Cirrus & Breeze
04-01-2013 12:09 PM
laura
04-11-2010 09:48 PM
soxfan
09-21-2008 12:11 AM
