2002 2.7L engine chirping
Old 01-16-2013 | 01:46 PM
dricetea's Avatar
Default 2002 2.7L engine chirping
My 2002 Sebring Convertible with a 2.7 L engine has started to chirp when it is cold outside. The chirping continues until the engine is warm and then it stops. It does not chirp when the outside temperature is in the mid to upper 40's or warmer. Anyone know what could be causing this? Thanks
Old 01-16-2013 | 10:47 PM
No telling what a "chirp" is, but it could be a drive belt. There are two of them. Might just as well change both of them. Probably due for a change on an 11 year old car anyway.
Old 01-17-2013 | 10:20 AM
dricetea's Avatar
The belts were changed about 2 years ago when the water pump was replaced.
Old 01-17-2013 | 10:46 AM
Nobody can diagnose a sound over the internet. Next time it's cold, open the hood before you start the car and then start the car and listen for the sound with the hood open. You may at least determine where in the engine compartment the noise is coming from. A two-year-old belt can still be a source of noise. Not all belts are of the same quality and that belt may have sat on a shelf for years before being installed in your car.
Andy_123
11-19-2010 11:47 PM
bluevolume
03-21-2010 08:54 PM
2002sebringgrey
12-03-2007 05:27 PM
ettienne
09-02-2007 12:29 PM
dcantu79
05-08-2007 10:11 PM
