2002 power window problems
Old 03-02-2009 | 03:06 PM
pauliwalnutz's Avatar
Default 2002 power window problems
The passenger and 2 back power windows will only work when using the driver's controls. The lights are on in the individual switches. Some kind of relay in the driver's door?
Old 03-02-2009 | 10:00 PM
Thre's a "Lock" switch at the driver's door that locks out the other switches to keep the kids from fooling around with the windows. I'm assuming you are familiar with the proper operation of that switch. It could have gone bad and need replacing.
Old 03-03-2009 | 08:33 AM
Thanks. I've played around with the switch but still the same problem.
Old 03-03-2009 | 02:44 PM
Then the most likely source of the problem is that lock switch. It's an integral part of the whole switch there, not a separate component. There is no relay in the circuit after that switch.
Joey-D
01-06-2019 01:34 AM
07pacificaNH
03-08-2013 09:08 PM
ronsemko
14
11-10-2010 08:00 PM
LT102
01-27-2008 07:45 PM
wmcleod
02-01-2006 11:30 PM
