2002 sebring ac problem
I have a 2002 sebring rag top this is the problem I have no cold air coming into the car. Here is some of the things I have checked.1 replaced the fuse and the relay. 2 replaced the head end controlswhere the AC switch is located inside the car. Now here is what I noticed the clucth on the compressor will not engage. at this time what am I missing hope some one has an answer
The refrigerant charge may be low. The car is 9 years old now so it should not be too surprising. The best way would be to have the system evacuated and pumped down, then add the proper amount of R134a back in. That way, you know you have the correct charge.
The quick and dirty way is to buy a can or two of R134a and a recharging kit and dump it it to see if that works. It might.
You may have other things wrong with the system, however, such as a bad pressure switch or bad compressor or clutch. It's not possible to diagnose the system from long distance.
muffinman14
01-10-2008 05:50 PM
2002, ac, air, charge, charging, chrysler, compressor, conditioner, conditioning, engage, pressures, problem, problems, r134a, sebring
