2003 Sebring Spark Plugs for 2.7L V6
Old 07-22-2015 | 02:39 AM
bocajoe's Avatar
Default 2003 Sebring Spark Plugs for 2.7L V6
Hi there. I'm looking for recommendations on spark plugs for my 2003 Sebring 2.7L V6. What plugs came factory and/or what plugs are preferred on a stock motor?
Old 07-22-2015 | 09:25 AM
champion platinum factory
Old 07-22-2015 | 09:28 AM
bocajoe's Avatar
Excellent... thank you very much CHRYSLER TECH!
Old 06-03-2018 | 05:14 PM
gpatel's Avatar
Default 2006 sebring 2.7 water leak, top left side of engine.help?
Hi my car is leaking water on left side of engine. I want to take that big black plastic thing off the engin but dont know what size bolts they are. Ate they metric or imperial, and what is the size please? There are about 5 maybe 6 bolts holding this thing down. I dont know what the leak is, but its set by the left side plastic thing with water air bleed valve on top. I am windering if it is cracked.
any suggestions welcome, but i need to know bolt size to buy tool. Is this a special deep socket or something, because i tried so many sockets and nothing fit.
there is no water in the engine oil. So what else can this leak be from?
thank you
gpatel
Old 06-03-2018 | 05:41 PM
The thing on top of the engine with the bleed screw is called the coolant outlet manifold. There are many entries here on the forum about it and how to remove it and what tool is required. (8mm flex head). When you say it's on the "left side of the engine" are you referring to where it is as you look at it from the front of the car? If so, that's the wrong way to describe it.
Old 06-05-2018 | 09:09 AM
gpatel's Avatar
Thanks dcotter0579, you reply above really helps me to now describe it correctly. Very Helpfull and informative!
keygar
01-31-2019 05:18 AM
Jose Vega
08-17-2018 05:43 AM
gpatel
06-03-2018 04:19 PM
queengsc
04-17-2012 04:26 PM
dbooth
09-19-2010 10:18 PM
