2004 Sebring cam position sensor trouble
I have 2004 Sebring 2.4L sedan. The motor stumbles when accelerating.
The engine light eventually came on, when it did I took it to autozone and had them pull codes, I got one p0340 (errors in the cam position sensor detected is what the printout said)
So I changed the CMP sensor and it didn't fix anything and the engine light is still on.
I took it back to autozone to pull codes and this time I got p0344 (print out said the same thing, detected errors in the CMP sensor)
I visually inspected the harness to the CMP sensor and the wiring and didn't find any loom with holes or shorts etc. I followed it back to the PCM (correct me if I'm wrong, second harness from the left when looking at the harnesses, it had a piece of tape labeled 'A')
There's 22 or so wires in this harness, and didn't know which ones to check for continuity. The CMP sensor has a black/blue, orange(?)/yellow and what looks to be a shielded ground.
Can someone help me with this? What else can cause this code?
0 replies wow is this forum dead?
Took it to a shop and they claim I put the wrong sensor in it. It was a duralast brand I got from autozone which matched their part number for this vehicle.
After some careful research I have found that sometimes sensors of this brand aren't of OE quality and may not work properly even right out of the box.
The shop put a mopar part (OE) in and it fixed the issue.
I am posting this simply incase someone is looking for this same incident.
mr.belvedere1954
07-29-2007 04:16 PM
