2005 idle low-400 any suggestions, help please
my 2005 sebring....mechanic says its the oil pump...but i believe its the low rpms...the oil light dissappears when i hit over 1k rpms....just wondering what could be the problem...lack of power and low idle and i change two o2 senors ....help please and any suggestions please.
Most likely it's the sending unit for the oil pressure. Replace that first. If that doesn't solve the problem, then you might need to tear into the engine, but the sending unit is a cheap and easy repair that should be suspected first.
The idle rpm's are governed by the engine computer. You can't adjust it.
chengthao85
06-11-2011 04:08 PM
mrorange
12-17-2008 09:37 PM
Esop212
04-28-2008 03:21 PM
startrak140
09-20-2006 02:34 AM
