2005 sebring a/c and radiator fan problems
I have a 05 Sebring with the 2.4 DOCH. Ther radiator fans will not come on and the A/C compressor will not engage. I have changed the high and low radiator fan relays and the A/C relay. I have also ran 12 volts from the battery to the radiator fans to test them. When I ran the 12 volts to the fans they worked fine. I also tried to recharge the A/C system but I could not because the compressor will not turn on. It overheats ofcorse when it is idileing and standing still. So I know the fans work I just dont know where the problem is in the system. I think it has somthing to do with the A/C I just dont know how to test the compressor or the rest of the system. Please any help would be greatly appritiated I am really stumped on this one.
I checked all the fuses on the car. I still cant seem to find the disconnection. I have not checked the eatx relay, asd relay, I dont know If they would have any thing to do with the fans. But all of the relays and fuses in the fans path have been replaced. I did try somthing the other day and got the fans to turn on I disconnected what i think is the AC refrigerant temp sensor and when i reconnected it the fans came on however when I shut the car off and then started it again the fans would not come on. Do you know the sensor that im talking about? It comes off of a ac aluminium pipe near the radiator on the passenger side of the car. Every time I unplug the wire and plug it back in the fans kick on. Could that be the problem? I also replaced the coolant temp sensor still nothing.
Do you think its worth replacing or should I look somewhere else. I mean I guess I kinda works because when I plug it back in the fans operate for a while I just dont know If its that sensor or if its the refrigerant in the system giving it a faulty signal. I dont know if it has anything to do with the compressor because that still wont kick on. Both of these problems happened at the same time thats why I think they are connected. But I have no idea where to start.
