2006 Chrysler Sebring Touring
...Round Plastic thing on top of motor i think called a: *Upper Air Intake* is making a Whining Sound........checked all the hoses no problems...no leaks......?........it only does this every so often but it is a problem that need's to be addressed. thanks.[:@] here is a picture of what is making the noise it circled n white......
[IMG]local://upfiles/6927/2F7F9EDA063A46DC84FC70905DDC5153.jpg[/IMG]
[IMG]local://upfiles/6927/8E6CA4A452CC429089EE6B8275E229A6.jpg[/IMG]
RE: 2006 Chrysler Sebring Touring
Yes, that's the upperintake manifold, but if there are no vacuum leaks, it's not likely to be causing a "whining" sound. It doesn't have any moving parts that would make a sound like that. The camshafts are nearby, and they are driven by a timing chain that could make a sound like that. The water pump is down under the passenger side of that area and might make a sound like that. You might want to invest in a mechanic's stethoscope to try to pinpoint the sound. It could be a few bucks well spent.
yea i just had an upper coolent hose replaced at the dealership cause i guess they said it was leaking is it possible they did something? cause it didnt make this noise before... othrn than that the car is awesome.... ok i have a quick question wtf does this round black gizmo do? i nvr seen a car with this upper air intake thingy before....
tkbelisle
08-17-2012 06:13 AM
jmaynard1986
03-26-2012 05:52 PM
