2006 sebring touring
Most probably, your blower resistor has failed. There is plenty of discussion about this item on the forum. If you search for it you will find it. It's an easy do-it-yourself repair.
Another possibility is that the control head (the part the ***** are attached to) has gone bad. That's another easy DIY fix, also discussed on the forum in several threads.
2006 sebring 2.7 water leak, topnleft side of engine.
Hi my car is leaking water on left side of engine. I want to take that big black plastic thing off the engin but dont know what size bolts they are. Are they metric or imperial, and what is the size please? There are about 5 maybe 6 bolts holding this thing down. I dont know what the leak is, but its wet by the left side plastic thing with water air bleed valve on top. I am wondering if it is cracked.
any suggestions welcome, but i need to know bolt size to buy tool. Is this a special deep socket or something, because i tried so many sockets and nothing fits.
there is no water in the engine oil. So what else can this leak be from?
thank you
gpatel
thank you
gpatel
lovelestat30
12-03-2008 10:45 AM
