2007 Sebring
RE: 2007 Sebring
FUSES/TOTALLY INTEGRATED POWER MODULE (TIPM)
A Totally Integrated Power Module is located in the engine compartment near the air cleaner assembly. This center contains cartridge fuses and mini fuses. A label that identifies each component may be printed on the inside of the cover.
Cavity
Cartridge Fuse
Mini Fuse
Description
40 Amp Green
Power Top Feed
20 Amp Yellow
AWD — If Applicable, ECU Feed
10 Amp Red
CHMSL Brake Switch Feed
10 Amp Red
Ignition Switch Feed
20 Amp Yellow
Trailer Tow
10 Amp Red
IOD Sw/Pwr Mir/OcmSteering Cntrl Sdar/Hfm
30 Amp Green
IOD Sense1
30 Amp Green
IOD Sense2
9
40 Amp Green
Power Seats
20 Amp Yellow
CCN Power Locks
11
15 Amp Lt Blue
Power Outlet
12
20 Amp Yellow
Ign Run/Acc Inverter
13
20 Amp Yellow
Pwr run/Acc Outlet RR
14
10 Amp Red
IOD CCN/ Interior Lighting
15
40 Amp Green
RAD Fan Relay Battery Feed
16
15 Amp Lt. Blue
IGN Run/Acc Cigar Ltr/Sunroof
17
10 Amp Red
IOD Feed Mod-Wcm
18
40 Amp Green
ASD Relay Contact PWR Feed
19
20 Amp Yellow
PWR Amp 1 & Amp 2 Feed
20
15 Amp Lt. Blue
IOD Feed Radio
21
10 Amp Red
IOD Feed Intrus Mod/Siren
22
10 Amp Red
IGN RUN HVAC/Compass Sensor
23
15 Amp Lt. Blue
ENG ASD Relay Feed 3
24
25 Amp Natural
PWR Sunroof Feed
25
10 Amp Red
Heated Mirror
26
15 Amp Lt. Blue
ENG ASD Relay Feed 2
27
10 Amp Red
IGN RUN Only ORC Feed
28
10 Amp Red
IGN RUN ORC/OCM Feed
29
Hot Car (No Fuse Required)
30
20 Amp Yellow
Heated Seats
31
10 Amp Red
Headlamp Washer Relay Control
32
30 Amp Pink
ENG ASD Control Feed 1
33
10 Amp Red
ABS MOD/J1962 Conn/PCM
34
30 Amp Pink
ABS Valve Feed
35
40 Amp Green
ABS Pump Feed
36
30 Amp Pink
Headlamp Washer Control
37
15 Amp Lt. Blue
110 InverterCAUTION:
[ul][*]When installing the Totally Integrated Power Module cover, it is important to ensure the cover is properly positioned and fully latched. Failure to do so may allow water to get into the Totally Integrated Power Module, and possibly result in an electrical system failure.[*]When replacing a blown fuse, it is important to use only a fuse having the correct amperage rating. The use of a fuse with a rating other than indicated may result in a dangerous electrical system overload. If a properly rated fuse continues to blow, it indicates a problem in the circuit that must be corrected. [/ul][/b]moe
Cavity
Cartridge Fuse
Mini Fuse
Description
40 Amp Green
Power Top Feed
20 Amp Yellow
10 Amp Red
10 Amp Red
20 Amp Yellow
Trailer Tow
10 Amp Red
30 Amp Green
IOD Sense1
30 Amp Green
IOD Sense2
9
40 Amp Green
Power Seats
20 Amp Yellow
CCN Power Locks
11
15 Amp Lt Blue
Power Outlet
12
20 Amp Yellow
13
20 Amp Yellow
14
10 Amp Red
15
40 Amp Green
16
15 Amp Lt. Blue
17
10 Amp Red
IOD Feed Mod-Wcm
18
40 Amp Green
19
20 Amp Yellow
20
15 Amp Lt. Blue
IOD Feed Radio
21
10 Amp Red
22
10 Amp Red
23
15 Amp Lt. Blue
24
25 Amp Natural
PWR Sunroof Feed
25
10 Amp Red
Heated Mirror
26
15 Amp Lt. Blue
27
10 Amp Red
28
10 Amp Red
29
30
20 Amp Yellow
Heated Seats
31
10 Amp Red
32
30 Amp Pink
33
10 Amp Red
34
30 Amp Pink
ABS Valve Feed
35
40 Amp Green
ABS Pump Feed
36
30 Amp Pink
37
15 Amp Lt. Blue
There are two places to find out what is what in the fuse box [TOTALLY INTEGRATED POWER MODULE (TIPM)]: on the inside of the cover of the fuse box and in the owners manual. If you need an owners manual you can download it from chrysler.com.
Thanks for responding. In the list in the handbook none of the lights are listed. My garage says the lights have to go through a fuse but I can't figure out which one. I'll try the download and see if there is more info
JeepInfoCenter
11-08-2006 11:41 AM
JeepInfoCenter
10-01-2006 06:34 PM
02-21-2006 11:00 AM
