2010 3.5 timing belt warning
I remember an issue on an older civic I had . When the timing belt broke all valves dropped and hit pistons and bent . Is this a problem on this engine . How hard is it to change timing belt on this car .
I called chrysler - $1300 to replace belt if not broken . My car has 85k miles and 2010 . I just bought it from Chrysler dealer used . I also purchased the top of line chrysler maximum care warranty for full coverage of additional 3 year 45k miles with $200 deductible . If I don't change timing belt and it breaks and causes valve damage - would chrysler max care warranty cover it during that period .
I was not sure if Chrysler would pay to replace the timing belt if it broke at 125k miles because they recommend replacing it at 100k . Also Chryslers Maxicare warranty states that wear parts are not covered - to include rotors , pads and " ALL BELTS "
I just had my concorde done and it cost me a little over $700.00 with the water pump at my local garage. Dealer charges too much and as long as you keep you receipt from a reputable garage, your good with your warranty.
Thanks for input - $700 with replaced water pump sounds good . I called chrysler - it's a Chrysler maxcare warranty - they said if belt breaks during warranty period they cover it and all damage it causes . I will double check again in several months to make sure this is correct info .
Poetheraven1
06-21-2011 03:50 AM
