2010 Console 12v output dead. Which fuse.
My wife's 2010 Sebring convertible console-mounted 12v outlet no longer works. The dash unit does, but the wattage on my oxygen concentrator often blows that fuse. We've had no problem, until recently, with the 12v in the arm-rest console. Since it seems to be dead, I'm looking for advice on which fuse to try. The mini-fuses all look good. Does anyone have a lock on which fuse supports that outlet?
Thanks. It's sort of important. We can't travel very far in her car without that power
JLOB
JLOB
Which fuse controls which component is inscribed on the underside of the cover of the fuse box. Similar information is found in the owners manual. Owners manuals can be downloaded from chrysler.com.
Failing that, trial and error should reveal a blown fuse, if that is the problem. Just because a fuse "looks good' doesn't always mean that it is good. There could be a wiring problem that is causing the outlet not to work. Unfortunately, outlets buried in the console are sometimes the dickens to access for repair.
Thatdudestl
01-10-2018 11:44 AM
